name this noise
yea but i dont boost either i get maybe 3-4 psi and thats it it also kinda boggs or floods when i hit the throttle i have a new manifold and gaskets on the way think that will fix it?
sounds like you blew a gasket out. Has to be something big if you're not getting boost, I had something similar happen and it was bolts in my o2 housing backing out and all the air getting out and just creating a massive leak
Ya sounds like a pre-turbo exhaust leak, either the manifold is cracked to hell or your gasket is done for or even both.. I would also check your manifold to head gasket and all the studs while your at it and replace it with a metal gasket.
This.
Also, you may want to check post turbo as well, this may be two separate problems. Check your BOV, I had the same boosting issue minus the exhaust leak noise. Ended up being I blew my BOV off the flange.
dsm, thats what i was thinking that it was pre turbo but still exhaust atm im using stock manifold with stock gasket, and thanks spawn ill check it in a few mins when i go out, so my walmart checklist is arp manifold bolts and metal headgasket :p
