Name That Plug!! =)
redeclipse7782
463
7
Oct 20, 2004
Worcester, Massachusetts
Can someone please identify these plugs/wires and let me know if I need to hook them up? the car is a 5speed 97 Eclipse GSX with a 6 bolt motor.
Thank You,
-Brian
1 is trigger wire for starter. PLugs onto prong on starter.
2 is windshield wipers
3 knock sensor????
4 same as 11
5 emissions crap
6 emissions crap
789 cant tell
10 same as 3
11 coolant reservoir fluid level warning light
12 fans????
13 ?
edit: Get wire colors and/or better pics of 789 and I can check on my car and see. Don't have my car here now to check.
Figured some out
2. Factory Alarm
12. o2 sensor (i had the cruise control plugged into it by accident) =) glad i havent started the car yet
3. Connects to the front of the transmission (looks like the knock sensor, but the knock sensor will only connect to one plug, which is already plugged in, thankfully)
I think #4 connects to the resevoir bottle, are u sure u didint mean #13 connects to that prong on the water neck?
I believe ravenous is right about #4 because there are actually 2 prongs there instead of one, it just looks awkward on there for some reason.
To recap:
1. Starter
2. Factory Alarm
3. Reverse Light
4. Boost Controller
5. Emissions
6. Emissions
7. ??
8. ??
9. ??
10. Is number 3 took pic twice on accident
11. Boost Controller
12. o2 sensor
13. Coolant temp gauge
I know 7, 8, and 9 are near the alternator and probably have to connect for the oil sensors but I'm not sure which ones go to which. I will take more detailed pics in the morning with color codes as well. Thanks again for all your help.
ooops thanks, fixed :thumb:
Haha I seriously did know that just been working on the car too long and must have been thinking about 7, 8, 9,
Ok I found the wire colors for 7, 8,9
First one is red/green stripe, and a black wire they look like the both go to 1 connector
They are near the starter but not the same harness.
Then there are three wires that come off the same harness as the starter
Blue/white stripe
White/red stripe
Yellow
Thanks again!
