1G NA rough idle, and grinds in gears
green4g63talon
Sep 13, 2009
depere, Wisconsin
i have a 93 1g n/t 2.0 and it just recently started to idle really rough between 500-1000rpm on cold and hot starts. but drives just fine doesnt seem to missfire when driving. on my way home from work today it had trouble going into first, and when it did it would grind. also it grinds going into reverse,and when down shifting from 4th to 3rd and 3rd to 2nd. clutch pressure good. slave cylinder and linkages seem to work fine, and has plently of fluid.
on my n/t the idler was fixed with a newer used ecu(mine was fried)
and the grinding is most likely your tranny
try mixing redline and syncromess fluids and putting that into your tranny
its made the grinding in my tsi almost unnoticable
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
