my tranny is got PWNED!!!!!
Turbo Monk3y
571
7
Oct 14, 2002
Orlando, Florida
Well last night i lined up against a modded wrx and we were pretty even off the line in 1st gear, i couldnt get it into 2nd he started to pull ahead but it finally went in with a split second mini grind. top of 2nd i was ahead 3rd i pulled 4 cars and shut down. Well when i turned around i noticed i could not get my tranny into 1st if my life depended on it... So now i got it home drivng using 2nd, 3rd, 4th kicks out at high revs but sometimes goes in, 5th and Reverse... If it helps it feels like the entire thing shifted to the right , meaning its harder to go into 2nd unless you hug the wall with the shifter... 1st feels blocked off it will not go up into gear... any fixes or am i gonna have to take my talon down for the next month and send my tranny to shepard?????? if thats the case ill have to pwn people in my Isuzu Impulse AWD turbo on the weekends its just as fast :p cuz its light as hell... ;)
Any ideas????
Do you really have to ask? Your tranny is toast. Your bank account just got "pwned."
Yeah, the cables are fine it seems like. There is no loose parts or anything, and the clutch pedal is fine. Im thinking maybe my tranny is toast but im not sure.... Its gonna at least be a month before i get this thing rebuilt :(
its done, send it out ASAP.
IF you drive more, you will wipe out 4th.....even if you don't use 4th. Probably third too.
Yep park it, i drove my old tranny for 5k miles grinding really bad in 2/3/4 and my magnetic drain plug was covered in metal shavings. Replaced the tranny adn sold the gring SOB on ebay for $20 :laugh:
hmmm how many miles on the trans???????? Did ur shifter ever move when you let it fall from a high RPM??? it could be ur end nut. over time the nut backs out. its the VERY last nut on the Gear\synchro packs. take the first case of the trans. its right there. just a little something to throw out there.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
