My stroker setup
rawbas
Oct 11, 2004
Chicago, Illinois
Well I just finished my stroker setup and just wanted too let you guys know what i've done so here goes
First off the block I used is out of a 1996 hyundai sonata 2.0 with only 30k-40k miles
The crank came out of a mitsubishi expo 4g64 from the junk yard
I had the block bored .20 over
wiseco forged 8.8:1 stroker pistions
stock 2.0 4g63t 6 bolt rods
balance shaft eliminator kit
copper titan sce head gasget
fidanza light weight flywheel
act stage 1 clutch
and thats it for now but I plan on putting on a 57 trim turbo that I have,having the head fully ported and polished,over sized valves,aftermarket cams,springs,beefed up trans and much more I also have a mitubushi td07-9 turbo I am thinking about using but I want find a smaller exaust housing before I use it.
this setup was suppose to be for my galant gsx but that plans changed for now but I will still be building a turbo motor for it just dont know if it will be a stroker I all ready have the wiring harness and computer and the block,we will see how this motor goes and then ill go from there.
Nice man...god i cant wait to get my motor back together. I acually had that turbo awhile ago...never looked up the specs on it or anything...but honestly i would just bolt that thing on or get the full specs on the turbo
