my RPM idle is going crazy
gmo
Nov 26, 2010
Kennett sq, Pennsylvania
Hey guys i have a problem with my RPM idle. After i drive my eclipse in town my RPM idle stay stock in 2000RPM and it does not go down and the tempeture start to rise up.I have change my regulator already thinking that would solve the issue,but not what can i do???
Change the MAP sensor ?
Or change the MASS flow sensor?
make sure your throttle cable has a little slack in it at the peddle as in you have to push the peddle in a bit before it grabs the ball on the cable. Also make sure the throttle cable isn't sticking, while it is idling high manually turn the throttle body plate closed and see if that changes the idle.
Noup guys it sis not work out.
i check everything and still messing up.
What i found was that, that right at the throttle in the engine part it gets just a little
off.
i try to adjusted the nut in the back of it and it didn't work.
so do i have to change the whole throttle???
