My rebuild parts list so far
I DSM KILLA I
120
Jan 11, 2009
Bensalem, Pennsylvania
Hey guys,
Updated list but still unfinished and showing current list prices (hopefully I can find some cheaper).
Tell me your thoughts!
Eclipse Parts List
Category/Part Price
Maintenance
Engine Rebuild Kit Pending
• Replace all gaskets, bolts, and other etc
Gates Timing Belt Kit $75.95
• Includes timing belt, accessory belt, and all pulleys
Gates Water Pump $55.00
• OEM Replacement Water Pump
Jack’s Trans Rebuild ‘Kit B’ Value $1299.99
• Rebuild/upgrade kit with 4 spider
Jack’s Trans EVOIII Kit $539.99
• EVOIII Conversion Kit
All new OEM Suspension $1068.49
• Control arms, lateral arms, and nuts & bolts
GSP Axles Qty 4 $279.96
• New OEM replacement axles
Driveworks Wheel Bearing- Front Qty 2 $143.98
• Front wheel bearing
Driveworks Wheel Bearing- Rear Qty 2 $194.98
• Rear wheel bearing
Beck/Arnley Front Calipers Qty 2 $126.98
• Front fully loaded calipers
Beck/Arnley Rear Calipers Qty 2 $129.99
• Rear semi loaded calipers
Brake Rotors & Pads Pending
Beck/Arnley Clutch Master Cylinder $89.29
• OEM Replacement Clutch Master Cylinder
Beck/Arnley Brake Master Cylinder $107.99
• OEM Replacement Brake Master Cylinder
ACT Xtreme 2600 + Streetlite Flywheel $678.69
• ACT Xtreme 2600 Clutch Kit & ACT Streetlite Flywheel
Walbro 255 HP Fuel Pump $95.00
• Includes install kit
FIC 1100CC Hi-Z Injectors $470.25
• Saturated/High Impedence Ball & Seat Injectors
Brian Crowler 272/272 Camshafts $359.95
• Includes intake and exhaust camshafts
Brian Crowler Adjustable Cam Gears $199.00
• Includes both gears
Brian Crower SS Intake Valves $129.50
• Stainless Steel Intake Valves
Brian Crower SS Exhaust Valves $129.50
• Stainless Steel Exhaust Valves
Brian Crower Valve Spring & Retainer Kit $199.00
• Chrome silicone alloy springs & titanium retainers
Eagle H-Beam Connecting Rods $345.00
• ESP H-Beam Connecting Rods
