Yuppitsthatkid
- 1
- Nov 21, 2012
Port Richey,
Florida
First off I'm having issues with my 98 Mitsubishi eclipse gs 2.4 4g64 automatic. The car will not shift while in drive, if park the car turn it off and turn it on and put it in drive it will drive threw all gears smoothly untill 3rd gear. Then it won't shift up or down. But I can put it 2 and it drops to 2nd gear but If I put it in 1 it won't do anything. What could it be?!? I've replaced the speed control sensors input and output. And if I let the car idle for 30 seconds after the 30 seconds it drops idle and try's to die. The strange thing is it has yet to throw any codes what cold it be, I've replaced the MAF and the throttle positioning sensor and the cam shaft angle sensor.
