my datalog look ok?
Flybiyou
304
3
Apr 8, 2003
somewhere, Illinois
mods are in profile didnt log the o2s casue my sensor went dead I have this sudden jerk\backfire but you cant hear any load pop just feels like the car shut down and then takes back off this is all on 93 and 22psi
rpm time air flow
2710 22 6.28
2871 15 8.50
3066 13 9.17
3269 14 9.93
3488 13 11.06
3707 12 12.49
3917 12 14.48
4164 11 16.35
4367 10 19.12
4683 9 22.54
4960 9 26.08
5183 7 28.85
5515 7 28.55
Heres where the car jerked
5394 12 28.24 the rpms dropped??
5894 9 30.52
6164 10 31.40
6351 10 31.72
6609 10 11.16
SECOND RUN
This run the car didnt jerk
3351 22 8.19
3480 11 11.53
3699 13 12.30
3894 12 14.39
4117 11 16.20
4378 11 18.50
4593 9 21.98
4882 8 25.82
5195 8 28.13
5488 8 29.27
5757 9 29.76
5960 10 32.26
6218 12 31.13
6472 12 31.48
6703 12 31.75
6843 12 31.76
7050 13 31.92
I think It looks good the timeing drops when boost comes on but then starts to climb
the thing that is getting me is that jerk around 5700 rpms any ideas.
Fix that 02 sensor!!
Also, timing should drop when boost starts, but your timing gets pretty low at some parts (7*) and that is not good...Have you done any tuning on the safc?? Maybe 22psi is too much for pump gas with the s16g...Seems like you get some massive knock, but then also your timing is way too low in the upper rpm's also....
It goes from 22 at the beginning of boost/before boost, and ends at 10-13* at the rev limit....That is not good
Fix that 02 first tho, that can really screw things up
Once again, another one of your posts that I don't agree with. Please explain to me why a dead O2 sensor is going to do anything more than screw up his gas mileage and throw a CEL for a FT malfunction. :confused:
To the original poster:
The ECU does not use the O2 sensor at WOT, only at cruise / idle, so that is not the cause of your problems.
A couple of things to check:
What is your spark plug gap?
What spark plugs are you using?
Have you done a leak test?
Post up your Ne points and corresponding SAFC-II correction factors along with your TPS switching points and we can start to figure this out.
HI settings low settings
1000 -8 -19
1600 -5 -21
2200 -13 -23
2800 -15 -29
3400 -15 -27
4000 -11 -26
4600 -14 -27
5200 -14 -28
5800 -15 -28
6400 -13 -30
7000 -12 -31
7600 -14 -32
30\60 tps switch
Plug gap is 30 I use bpr7s
did a boost leak test holding pretty good except my bov opens at 11psi Thats another post though If you care to look at it its in problem diagnose under (question on evo8 and 1gen bovs. ) sorry it took so long to anwser had some stuff come up .
I just said it would screw things up (ie your car's normal behavior)...I do consider poor gas mileage and CEL's as "screwed up"....
I don't really wish to look at a whole different thread, but if you are saying there is a leak at the bov then how come you haven't fixed it yet??
rpm time air flow
2710 22 6.28
2871 15 8.50
3066 13 9.17
3269 14 9.93
3488 13 11.06
3707 12 12.49
3917 12 14.48
4164 11 16.35
4367 10 19.12
4683 9 22.54
4960 9 26.08
5183 7 28.85
5515 7 28.55
5894 9 30.52
6164 10 31.40
6351 10 31.72
6609 10 11.16
SECOND RUN
3351 22 8.19
3480 11 11.53
3699 13 12.30
3894 12 14.39
4117 11 16.20
4378 11 18.50
4593 9 21.98
4882 8 25.82
5195 8 28.13
5488 8 29.27
5757 9 29.76
5960 10 32.26
6218 12 31.13
6472 12 31.48
6703 12 31.75
6843 12 31.76
7050 13 31.92
5k, 6k, and 7k, look totally lean. YOu should add some fuel on these rpms. Your goal is at least 16-17 degs of timing on PUMP GAs.
Exactly what the guy before me said. You need to tune your car strickly by the amount of timing being pulled. I had the same problem with my car though. Mine actually turned out to be the stock FPR being overflowed. The fuel would get backed up in the fuel rail and forced out the injectors making the car run super rich and it would pop just like it was hitting fuel cut. Just my two cents. :thumb:
