My custom made intake manifold
Stez
106
Feb 16, 2005
Kiev, Europe
I'd like to show to you guys my custom made intake manifold, curiouse to here your opinion of this :)
i didnt drilled the vacuum ports yet.. will do it soon before install...
As for dynosheets - unfortunatly i have no one with stock manifold :( so probably will have no possibility to show the comparison sheet.
From the other hand, i can tell that my stock manifold is in bad condition, very pure inside with black deposit.. so i'm sure that this one will perform much better.
Hey where did you get the flange that connects to the head or did you make it your self.
Everythings were made with ourselfs including flanges. The diameter of the plenum in 110 mm (for example the SBR plenum is only 90 mm) so its only looks small, in real its pretty big. The diameter of runners is 54 mm and plenum flanged for stock 1g TB - 60 mm.
