My car little build part 1
pur97tsifwd
331
Jan 31, 2006
Nevada, Missouri
Fixing a few things wrong with my car turned into a little build while i had it apart here is the progress.
I have removed the rear end installed energy suspension bushing. Painted some of my rear end working on painting it all. Undercoating the whole car not started yet. Fixed some water leaks and removed some rust and painted over it. Installed me a safc and working on a pocketlogger setup. Bought me new struts all around just monroe oem with oem springs soon to install. Put rear end back together and then I will be pulling the motor out fixing a couple things like timing plastic back on. Fixing some stripped bolts. Removing the balance shaft installing a 2g maft.
  • Wanted 6 bolt NT water pipe
    • chrisman287
