My car is dripping water
pixelfuture
37
Jun 20, 2005
lawrence, Kansas
Somewhere in the middle of the engine. It's not very much at a time and doesn't happen after each time I drive. How can I fix this?
are you sure its not coolant that is dripping? clean the bottom of your engine very nice and the next time you drive look to see where its coming from. it can be from a hose to a head gasket.
What color is the liquid.For example does it look/smell like coolant or water or what?You can check all your cooling hoses for tiny leak's.Some times if you've been messing with your hose's you could have maybe not have tightend one of them up enough.
Get your nose under there and find out what the hell it is. I'm with the condensation from the AC, especially in Kansas in the summer.
Well it's clear, when I touch it it feels like water, and doesn't smell like anything. But it very well could be the coolant because now that I think about it, it only happens when the AC is on.
If it happens only when your AC is on, then as they stated above it is condensation, don't worry about it, its normal.
Thanks for the help guys. I appreciate it
