ms ordering question
Lamar9875
30
Apr 16, 2008
Fort Knox, Kentucky
Here's my setup
420a 2.0
Super 16G Turbo
Stage 2 Hahn Setup
Walbro 255 fuel pump
Fidanza cam gears
JE Pistons 8.8:1 compression, crower I Beam rods
Stock Injectors
Right now I am at 6psi, going to raise it up to 10psi
Next week I want to order a assembled unit, since I am no good with wiring :cry:
But what would be a good unit to get? I looked and searched and found more about this one MegaSquirt-I Programmable EFI System PCB3.0 - Assembled Unit, would this be good when I raise the boost and do more engine work as far as bigger injector's etc.. thnx :talon:
The Megasquirt-I v3 is what I'm putting in my Talon. I am going to run it with my MSD Ignition module. I think this is a good choice.
I'll be running mine on my 4g63 "stroker" 7 bolt.
block bored .040 over
4g64 (2.4L) crank
eagle hbeam rods, arias .040 over 9.1:1 "stroker" pistons
BC280 cams, fully ported/polished head, nitrated valves
custom-home made intake manifold (in progress)
1000cc injectors
MSD Coil Pack + MSD Ignition Module
and either a 4088 or equivelent turbo with 3" everywhere.
I've also heard you have to modify the board to work with are dsm's, if so how is this done. Since I'am new at tuning I looked at HPTuner a pnp but I have'nt really heard to much about it just that it cost more than ms
