motor
kinda a loaded question but ill answer the best i can
bone stock and well maintained you can get a manal boost controler and turn the car up to 12-13psi safely --- im assuming you have an aftermarket boost gauge to monitor that
now the other part of the question
if you have the supporting mods: ie Fuel pump, injectors, SAFC or some kind of tunning device, Wideband to monitor Air Fuel Ratios --- -the list goes on and on of course -- just do some researching
if you have all of that then the magic number ive heard alot is in or around 20 psi
thats without touching the motor
hope this helps
It all depends on the mods. I think your looking for 1 of 2 questions. Either how much boost can you push stock or how much hp can the motor withstand. More importantly if you haven't already on a car that old you need to do your maintenance and supporting mods.
Here is the tech guide for your car.
Tech Guide: 1G 4G63t Upgrades - DSMtuners
Before you start another thread next time try using the search feature found here.
DSM Forums - Search Forums
  • Wanted 6 bolt NT water pipe
    • chrisman287
