Moonroof Problem
prompt
76
Sep 11, 2004
Biddeford, Maine
Ok, Just bought my Red 96' GSX about a week ago. I'm starting to go through things in the car. I noticed that the moonroof doesn't go all the way down on the passanger side(just enough for water to get in). Tried pushing down while I pushed the open button. Didn't work.
Another Question...Does the 96' GSX moonroof slide back? If so what would be the problem of that not sliding back? I know the front end of the moonroof has some rust(most likely from the water leaking down the tracks towards the front from the open spot). :confused:
best thing for you to do is remove the glass (6 hex screws i think inside on sides of glass) and look at the cables and assemblies.... If you are looking for a used moonroof for parts i could sell you one that we bought and never used (since we fixed our old one) for a lil cash :D
What bored* said is pretty much right. I had the same problem with my '95 after I had a huge chunk of ice hurled at my open sunroof a few years back - and it wouldn't close. I unscrewed the glass and just had to reseat the assembly on the track. It doesnt take much to get it all done - maybe a half hour.
Best of luck.
Ty Vm Defiant that manual helped a lot. So I guess the 96' model doesn't have a slide back feature tho :(
I'm not sure what you mean- the sunshade slides back, but the glass tilts up at the back, then slides back over the roof. All the 2Gs are the same, unless you've stumbled across a freak that has an after-market sunroof on it.
