Moisture In The Headlights!!
16g Spoolin TSi
126
Feb 19, 2004
Merrimack, New Hampshire
I've been searching for some aftermarket headlights after noticing moisture in my passenger side headlight however after searching ebay i can only find the ones im looking for: Halo- Projectors for the 97-99 bumper... anyone know where i can go to get headlights for the 2gA bumper style?
~Johnny
take the headlight out, take the bulbs out, and stuff a blow dryer in it.
that should take care of the moisture problem. as far as finding the headlights, I dunno.
You can fix your headlights so they don't draw moisture, it's really easy!
1. check the little rubber drain tube on the bottom for debris, as this is a major culprit.
2. Remove the clips that hold the outer lense to the housing, they just pop off.
3. carefully remove the housing from the lense(vice-versa), you may need to take a razor
blade and go around the seal.
4. Find some good epoxy sealer, I prefer windo weld(black urethane) by 3M, but I wouldn't recommend it if you've never used it before because it's nasty stuff and won't come off anything it touches(hands, cloths, etc)
5. With a small bead of a good epoxy sealer in place put the housing and lense back together...........and BAM! instant new headlights, well at least close to new! :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
