tweek814
- 86
- 0
- Nov 20, 2009
Charleston,
South Carolina
Hey first off here are the codes i read with an obdII scan tool -
P1400 Manifold Differential Pressure Sensor Circuit Malfunction
PO505 Idle air/control Motor Malfunction
P1105 Fuel Pressure Solenoid Malfunction (turbo)4g63t
Cleared the codes yesterday and they came right back overnight.
Anytime I go over 10 psi, give or take, wot, theres a heavy miss. I turned boost down from 16 to about 13 and it seems to have helped to an extent. Most noticible when your wot in 4th or 5th gear at low rpms/full boost. Gonna do plugs, wires, replace iac (idle surge once and a while) and go back to stock o2 manifold. (has o2 dump atm) would do the fuel filter but i learned my lesson last time, ill save that for another day.
car is 96 tsi awd, boost controller, o2 dump, 3" o2 back exhaust, air filter, boost a/f gauges, 5 speed.
thanks in advance gurus!
