2G Mishimoto radiators fitment
EVLGSX
5+ Year Contributor
655
258
Dec 7, 2017
Wallingford, Connecticut
Hey guys-
Looking for some feedback on the fitment of these units in a 2g. Id also like to know if the 3 row is worth the space it takes up over the two row and if it will fit reasonably with their slim fan/shroud set and allow the FP green/red setups. Thanks!!
http://www.streettunedmotorsports.com/parts/mishimoto_dsm_aluminum_radiator.htm
http://www.streettunedmotorsports.com/parts/mishimoto_dsm_aluminum_x_line_radiator.htm
http://www.streettunedmotorsports.com/parts/mishimoto_performance_aluminum_fan_shroud_kits_mmfs.htm
I've run the dual core Mishimoto's in several different setups, never had a problem. I currently run the dual core with a main Spal puller and a pusher on the drivers side, no cooling problems. By some quality fans and you will be good to go.
Yeah I think the dual core is the way I will end up going......The 3 row is a little less than a 1/2'' more but every bit of the space counts in that area..... especially if an external gate comes into the setup
No I'm saying too many spend the money on the radiator and cheap out on the fans. Do the opposite. I run the 2 row with a stock ac fan and a spal pusher. Can handle Florida heat with AC. Only after some ducting though.
Thx for the link. I trimmed my bumper very carefully to leave no more than 1mm between it and the IC all the way around but didnt plan on adding anything to it......hopefully its enough for those brutal summer days with th A/C in traffic
I run the 3 row. With 1 stock A/C.
It dropped my temps like 10-15 degrees if I remember correctly. But it's still not good enough (sits at 196-203) most of the time.
I keep telling myself I'm going to start duct work and pusher fans. But life keeps happening and money goes elsewhere.
The most noticeable change happened though when I modified my stock fan shroud to sit flush against the radiator. Basically just enlarge the holes so they go over the mishimoto fab mounts.
I tried using weather stripping at first but it wouldn't stay, as it took 3 layers to fill the gap.
