steel_3d
- 494
- 14
- Jul 3, 2003
LA,
California
I'm a little bummed at the moment since my brand new engine is starting to give me the same symptoms as the previous one did when it blew the head gasket.
Basically I'll be driving on a flat highway at a constant cruise, or even downhill, and suddenly the car starts stuttering, misfiring. It's a very regular misfire like one cylinder stops firing completely. Letting off the throttle or giving it more gass, or playing with it in any way doesn't help, until I push the clutch in and let the rpm's drop to idle. Then I can go again for 5-10-15 seconds before I have to repeat. If I drive below 70 it seems to do a lot better and exhibit the problem much more rarely. If I go above 3000rpm the misfiring becomes more and more frequent. This only starts happening after a few miles of driving, when things are nice and warmed up.
Now given that this is the same problem I was having last year with the blown head gasket, requiring the same driving style, this is my theory: At higher rpm the water pump starts pushing coolant into the combustion chamber, eventually killing the spark. I'm assuming at idle there's much less water pressure and the engine manages to burn off whatever's in there and is able to fire again.
The problem seems to be more rpm dependent than load dependent. Usually when it's an ignition system problem, the issue occurs with higher load, but I have no problems accelerating as long as I'm below about 3000rpm, and if I'm above 3000 it misfires whether I'm accelerating, decelerating, or cruising.
I'm hoping you guys might have seen an ignition component failure that behaves this way, cause I can't really see definite signs of a blown headgasket, but it's probably wishful thinking...
I get no white smoke, no coolant loss or overheating, can't see fluid in the cylinders or on the plugs. On the other hand my plugs are white (o2 logs are iffy at wot, sometimes .94v, sometimes 80's, but at cruise and idle they always cycle nicely), and the logs show low timing at wot, like 15 degrees, sometimes tapering, sometimes rising. The knock graph on the other hand is not any different between a steady cruise or revving in neutral versus a wot pull with low timing. I'm using ecu+ so all I get is a spiky raw knock voltage graph. I was runnig 50% 100 octane, and only 8psi on a 14b for breakin, so I have a hard time understanding how I could have blown a head gasket. (I was still a moron for not taking the time to look through my logs carefully, just relying on the knock graph). This is a stock composite gasket with copper spray and arp's torqued to 85ftlb with lube, retorqued after a few heat cycles. Both surfaces were machined. The only questionable thing is that I put it on a 40 over bore. It wasn't quite sticking into the bore, but it was very close. Hope I didn't burn the fire ring.
Oh the only other weird thing that bears mentioning is that I advanced my exhaust cam 5 degrees and retarded the intake 5 degrees to get my FFWD 272's to idle nice.
Anyways, that's a lot of conflicting info, that's kinda why I'm throwing it out there, in case someone's seen the same thing before. I really don't wanna take the head off unless I'm sure. (No, I don't have any vacuum leaks
I know this is a newbie forum, but please no newbie replies
Haven't been on this forum in years...
Any suggestions??
