MBC in car adjustment cable?
insanewayne
317
May 18, 2004
Ladysmith,
Could someone who has the Hallman evolution pro MBC or whatever it's called let me know how the in car adjustment works? I was thinkin of attaching a cable or some sort or system on the dial and running it into the car, but don't want to have the cable twist 1080 degrees before it actually starts adjusting the boost. It would suck not knowing what boost i was running till i see my gauge pin at 30 VAC hahaha :thumbdown :p (joke, I'm not that dumb.....really! I'm not!)
Thanks
Wayne
I had a dual stage in my car for a while but now I have an MBC running 18 lbs daily. It was nice to say I can switch from 10 lbs to 18 lbs just by flicking a switch but even that wore out after awhile. I ended up always leaving it on high and whenever I had it on low and wanted to play around I found it was still a pain to hit a switch (which was just mere inches from my shift knob) just to do so (just got tired of it I guess) and then set it back to low when I was done. Anyway, I just wanted to share my experience with so called dual boost contrller. So I understand the "wanting" or even "needing" of changing boost setting on the fly but I like things simpler now, just get in and drive. :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
