General Maxed out fuel trims?
I-luv-em-all
602
5
May 25, 2004
Regina,
Ya I don't know much about fuel trims, and all of the previous posted all had some kind of tuning problem and what not. Well I don't have any aftermarket fuel or controller or anything. Just a fuel pump rewire. And all of my fuel trims are just high, all of them are around 137.9, 138.9, 139.9%. Any clues?
I'm having the same damn problem bro...But i think i have mine pinned at a bad ECU...Good luck..Fuel trims can suck at times...dan
they should be at 100% have you triedto adjust them at idle first.
trbotaln said:
not sure but you might have a bad o2 sensor.
All you have to do to find this out is see if it cycles. See if it goes from .2v or so up to .8v or so at cruise. If it doesn't, your o2s is bad or the wires are bad.
