max power from amp...
turbo98eclipse
1,096
15
Jul 27, 2004
northern, New Jersey
i got my subs working thanx to you guys on here, now im trying to figure out how to get the max power from the amp...
i have my subs wired in a (series/parallel) = 4 ohm load
but im confused on how to get the "max power" from my amp as listed below....
rms power @ 4 ohms 65watts x2
rms power @ 2 ohms 125watts x2
max power output 750 watts x2
does the way i wire the speakers affect the amount of power im getting from the amp to the speakers themselves? :confused:
Yes it does, try going here:
www.bcae1.com
It's the best source I've found for all my audio/electrical physics needs :)
Use the scrollbar on the far right to find what you need, everything you should need and more should be here, Good Luck with it :thumb:
