master cylinder help asap ###
jdunbar10
133
Jan 30, 2007
edmonton, AB, Canada
ok so here is my question
i am not getting enough pressure for my clutch system, i can not engage my clutch with out it trying to grind,
i have no leask anywhere
the system has been blead over and over so there is no air
i dont have alot of money atm so i cant afford to buy both the slave and master
if i pump up the pedal i cann temp. have enough force to put in my clutch
does anyone have any ideas and my main question does anyone have a exploded view of the master cylinder, i found a small cap in my resoivor so i need to know if that is possible my problem
Try this out, if you have bled the system alot and you know your master cylinder and Slave are good than try this either way do this. Any leaks on the firewall of your master cylinder? Any leaks with your slave cylinder? Pull the boot back check the slave.
Clutch Adjustment
yeha that was one of the first thing i have tried also... thats also why im stuck i have almot no toe lash at all like 3/4 of a inch
Well if you are having those troubles I would try the Slave Cylinder if replacement. Go on Rockauto.com and order one from there they are cheap but autozone has a lifetime warranty. Also the master and slave don't have to leak to be bad, so keep that in mind. Maybe one of them is going out. Did you already check your transmission fluid? Drain it out check to see if it's black and/or has metal shavings in it. If it does have metal or is black something is wrong inside the transmission. But your fluid could also be low causing a grind.
