Manifold for externally wastegated turbo
GsXdSmKingGsX
4,576
33
Dec 13, 2008
Plainview, Minnesota
:pray:I need a good manifold for my externally wastegated Turbonetics T3/T04E Hybrid turbo. I find alot of manifolds but none of them had a place to mount my wategate. PLEASE HELP
Its a TiAL 34mm wastegate and yes i want to mount it on the 02 housing of the manifold
You have 216 tech posts, but yet you do not know this answer? And you need to clarify what you mean. You can either mount it on the exhaust manifold, or the o2 housing. I don't know what "o2 housing of the manifold" means.
What?
You can mount it on one or the other. If you want it on the o2 housing, you don't need to buy a manifold with a wg provision.
You have 2 choices:
1. Mount it on the exhaust manifold
2. Mount it on the O2 housing.
Now as far as the tial, I've never seen a 34mm. I've seen 38mm and 44mm.
Here is an example of punishment racing's recirculated o2 with a 38mm tial.
Here is an example of punishment racing's t3/t4 exhaust manifold with a 38mm tial provisioning.
Pick your poison. Personally, I prefer the O2 because the provisioning for the wastegate off of the manifold typically only goes on 1 runner instead of collectively from all 4. That is not the case on the above pic.
d
Thank you to PR for making it easy to link to their pics.
Sorry sir i meant 44, and to clarify i meant the exhaust manifold. i had just woken up when i posted that so i was a little out of it.
And yes i have 218 tech posts but i JUST recently upgraded my turbo and had trouble finding help on this matter.
If you are looking for inexpensive I have heard great things about the OBX T3/T4 manifold with a square 44mm wastegate flange.
