Major Problem. Help Fast.
jeffreyinigo
65
Oct 6, 2004
Tucson, Arizona
ok guys i have a major problem. i was driving down the highway today and decided to stop cause my car was having some kind of engine problems i think. so i stopped and when i went again, after i was going to shift to second i pressed the clutch and it went to the floor and heard a crack and i took it to a gas station see what happened.
i turned off the car and noticed that a whole bunch of tranny fluid started to leak, i mean a lot. so then i tried to move the clutch up and down and noticed that also clutch fluid was leaking. so i realized that the slave cylinder was messed up and that i need to replace that. thats not a problem. the problem is the tranny fluid leak. what could have happened?
i need some serious help guys. thanks
id check your Seals Axle seals. other than that could be internally in the trans only way to tell is by removing your trans and taking a look.
Jesse
