Rock2610d
- 255
- 4
- Jan 22, 2013
Cheyenne,
Wyoming
At 14.6 seconds into this log my boostest went to 56 psi, coolant temp went from 193 to 90, baro went from 23 to 10, battery volts went from 14 to 11v, wideband factor went to -96, etc....bunch of bad readings. see log.
At 14.8 seconds everything went back to normal....should not be a bad ECU as it was sent in for a socket job and inspection just about 6 months ago.
Looks like a MIL was triggered but no record of it in Link other than the 1 after 14.6 second.
Can anyone tell what happened during this .2 seconds?
but you should really check your grounds, and power wires cause it seems like some electrical surge happened that made everything misread, because theres NO WAY you hit 56psi on a T25. Check your battery too.
