MAF, what did i do?
Detail
Supporting VIP
546
147
May 28, 2003
Marietta, Georgia
just topped 140k miles. So I decided per some reading I had done on the internet to clean up the intake a little to see if I could make it run a little better. SOOO, I pulled off my injen pipe and filter and disconnected the maf and hoses. pulled all of those things apart from the maf. I cleaned the filter with a K and N cleaning kit. I cleaned the inside of the intake pipe with degreaser and sprayed it all out. Then I took the MAF and cleaned it with electronic parts cleaner from radio shack. I let it all air dry. Then I reoilled the filter and put everything back together. I installed it in the car. Cranked it up. And now it won't idle at one point. Its hunting from 500-900 rpm. So I figure I didnt dry it enough. So I pull everything back out and gently (20 psi or so) blow everything out with the compressor. Its dry for sure now. Reinstall again. Same thing. I pulled the car out and drove it. It drives so so above 2k but feels extremely rich. WHAT DID I DO????!
mods:
intake, exhaust, supra side mount, afc (at all 0's), blitz boost contr
MAF has everything intact, no honeycombs removed or messed with.
Oh and I reset the ecu per unhooking the battery, still no fix.
I'm really worried, can't you tell...help
