lower damper fork bolt
Saturdee
405
Nov 9, 2010
Duncannon, Pennsylvania
This stupid bolt won't come out. I'm trying to get my driveaxle out on my passenger side to replace it, I took the screw off of the lower damper fork bolt, and I tried unscrewing the bolt but that didn't work cause the rubber thing started spinning, then I tried hammering it out, that didn't budge it. I don't know what to do, someone please give me a hand with this, thanks.
Cut it out then go to the dealer and buy a new bolt. I think I paid $9 when I had the same problem. I used a sawzall with a fresh blade and some cutting oil on it. The bolts are pretty hard and take a while to get thru.
Not sure exactly what bolt you are referring to. If it is the one where the front sway bar connects to the dampener fork then there is a nut behind the bolt to back it up. 14mm wrench i think it is.
Well it's loose, I just don't want to twist the rubber in the damper fork. Maybe I could try a c clamp and try to force it through?
You could give it a try. i took a air hammer to mine to try knocking it out aswell with no luck. If id have to do it again I would just cut it out from the start instead of fighting with it for a hour or so.
Its rusted in the sleeve in the bushing and when you broke the bolt losse it ripped the bushing apart. You are most likely going to need to replace the control arm as well
Of course I am. It seems every time I try to take something off down there I need to replace it cause a rubber boot either rips, or tears like it probably did.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
