Clutch Damper??
Oppi
Jul 6, 2008
Charlotte, North Carolina
Found clutch fluid (brake fluid) leaking at clutch damper, so bypassed the clutch damper, and ever since then, had low pedal pressure. Can anyone tell me what is a clutch damper and whats the purpose of it??? I also swapped out the master cylinder as well, so problem could exist at the new master cylinder... as for now, i'm clueless about the clutch damper...
i belive on the 2gs they have a restriction valve if some sort to control the fluid pressure in order to make it easier to drive, you shouldn't have a low pedal by removing it.did you try adjusting the rod that connects the pedal to the master cylinder?
yeah, ive tried bleeding the whole system, and adjusting the rod on the master cylinder, and also replaced the slave cylinder, but i think the master cylinder is just defective, for some reason i always get the messed up ones... :notgood: but as for the clutch damper, it is on a 2g and ive taken it off completely. So all it does is makes it drive easier???
yes, to the other question too, it is mounted on the transmission but before the slave cylinder...
oh ok im not familiar with that then. i also just replaced both the master and slave and had not 1 but 2 defective master cylinders. :notgood:
yea, i'm going to try another master cylinder, thanks for the help guys...
So, bypassing the Damper (clutch FSU) actually helps give the pedal more pressure. :thumb:
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
