low rev limit
carfiftyfour
Jun 26, 2006
troy, Pennsylvania
i have an 91 2.0 that the ecu was smoked , ive changed the ecu with another and the revs only get @3800 the it cuts out what is the fix thanks:beatentodeath: :beatentodeath:
thanks for the tip the tps was checked and was found to be in spec.. so by process of elimination i disconnected the mass airflow assembly i got my rpms back and the power but no idle of course..any other help ive switched with 3 diff. air sensor assy 2 of which are known to be good :confused: :confused: :confused: :confused:
