2G Low idle at start up for 2-3 minutes then idles fine?
PaulKemoSabe97
May 4, 2016
El Paso, Texas
I have a standard 97 GS-T with a 6 bolt block and 7 bolt head other than that everything else is bone stock!! My problem is anytime I turn it on (engine being warm or cold) it'll fire right up but idle low between 3-8 rpm's for maybe 2 to 3 minutes then will rev back up and run fine after that. I've read a few threads here and there on this site and tried a few things like my tps, o2 sensor, iac but I still have this problem, if there is anything else I can check to try and fix this I'd appreciate the help or input
I would adjust your biss properly first off (you ground a terminal on the fire wall witch will stop your isc from screwing with your idle when you do that it should set it to like
40-50 )
also you adjust your idle to Your desired idle (every cars different I do 800 rpm )
Just search how to do it on here
Edit: http://www.vfaq.com/mods/BISS-1G.html
<--- this explains it better than I could
Bet your maxing out your isc to 120 which causes a lot of issues
It wouldn't hurt to check your ignition timing to with a timing light
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
