low fuel trim code
emeracing
63
Sep 3, 2014
oakhurst, California
ok i have 95 eagle talon tsi. i just replaced the exhaust manifold and exhaust housing side of turbo and spark plug wires and fuel pump and now all of a sudden im getting a low fuel trim code and i cant figure out y i replaced the IAC brand new and still same thing and everything i replaced is new OEM replacement parts so i need some ideas please
low, like a negative fuel trim (the ecu is pulling fuel), right? Maybe you just have way better fuel flow with the new pump. What was the code, P0170 ?
let it hit operating temp so it will go into closed loop. when the car goes into closed loop the O2 voltage should be constantly switching from hi to low. if it doesn't switch and just stays high or low or in the middle, or it switches to slow it should throw a code. it wont always but if your lucky.
you can see where it warmed up and still didnt close loop i saw it close loop once as warming but went back to open and stayed
Well I might start to suspect that o2 sensor or a large exhaust/air leak .
But you'd likely hear the later.
Have over 25 years of working on vehicles a handful of o2's give up the ghost after being removed/reinstalled.
