low compression
paul s
625
6
Nov 17, 2002
kingston, ON, Canada
Hey, I just checked my compression and it is even 150psi on each cylinder. A month ago it was 178psi. The car is boosted to 25psi daily and seems to drive OK. Do you think that it is the rings or bent valves, there is no abnormal noises. I usually shift at 7500rpm(HKS springs, 272/272). There is 16inches of vacuum at idle(1000rpm)... :confused:
Would the rings all lose compression so even? thanks Paul
I need to do some travelling this weekend and just wonder if I should take another car.
It's highly unlikely to bend valves or eat up rings so that all cylinders read the exact same compression numbers. I'd attirbute it to general variables (temperature, number of cranks, weather, etc), but if you're going on a road trip it wouldn't hurt to do a leakdown test.
I don't have the proper gauge to do the leak down test. I did someting like that, I took compressed air and put it in each cylinder and there was no leaks from the intake or exhaust manifold and if there was leak through the rings I could not hear it..??? :confused: I will try putting some oil in the chamber to see if compression goes up..One thing I didn't do was to hold the acc pedal down while cranking??
  • Wanted Wtb t25
    Looking for t25
    • Talontek9
  • Wanted WTB Volk 2G AWD Subframe bushings
    Looking for the solid rear subframe bushing set for a 2G AWD.
  • For sale 4G63 Kiggly Racing 6 Bolt to 2G Auto Transmission Adapter Plate
    Kiggly Racing 6 Bolt to 2G Auto Transmission Adapter Plate $100 + shipping & paypal fees*...
  • For sale 4G63 ARP 7 Bolt Head Studs
    ARP 7 Bolt Head Studs $65 + shipping & paypal fees* torqued onceYou must be registered to...
  • For sale 4G63 NEW ARP 4G63 Main Studs
    NEW ARP 4G63 Main Studs $50 + shipping & paypal fees* these are $81 onlineYou must be...
