Losing all my Juice at high Acceleration!
QuickClipse2
190
Jul 4, 2003
Rohnert Park, California
Whenever i want to pass a riceboy Honda or just decided to feed some speed to my ride the car acts like it would in neutral when its in gear. Scenario: I shift to second and apply pressure to the gas= feels like revving in neutral and no go. This really sucks balls :cry:. Whats wrong with my car?
You can try a few things. Check the master and slave cylinder for leakage. My wife's 97GST was doing the same thing and when I pulled back the boots on both cylinders, brake fluid flowed out all over the place. I replace the slave and rebuilt the master and haven't had any slippage since. If those are fine then you can try to adjust it by moving the master cylinder push rod by the clutch pedal. If all else fails, then your clutch needs replacement.
Good luck,
Steve
