Looking to upgrade turbo wanting suggestions
wvturbo2
1,164
Jan 25, 2006
Huntington, West Virginia
I have a 17c right now that is ported and i know its not going to push alot of boost. I was going to run around 19 to 20 psi which isn't real efficient on that turbo. I have a 190lph fuel pump with pte 680cc injectors. Should i upgrade to an evo 3 16g or a sleepers 16g with the 20g compessor wheel or even a 20g. I figure the 20g is past the 190's limits. Let me know what you all think thanks.
20g would be past the 190's limits. A 16g evo or 20g bastard wont make much more than 350whp. If you want more than 350whp than I would go with the 20g/50trim or bigger. Matters what your goals are.
if you are going to keep the boost at 19-20 psi the evo 3 16g seems like it would be a good choice for you, if you have any plans of raising the boost later on id say start looking at bigger turbos.
If i do the sleeper or the a evo3 i'm going to want to raise the boost part 20 most likely. Around 350 whp would be good for me.
