look what i found.."4.3 LITER VOCTECH" Talon
TurboATM
1,243
9
Aug 17, 2006
Jacksonville, North Carolina
hahaha..pulled from a craigslist ad in Charleston SC...(im not pushing this ad for him or trying to sell anything, so mods, dont get the wrong idea...LOL)
****1994 EAGLE TALON***** OBO - $650 (OBO N.CHARLESTON)
Reply to: [email protected] [Errors when replying to ads?]
Date: 2009-03-17, 1:11PM EDT
1994 EAGLE TALON $650.00 OBO 4.3 LITER VOCTECH ENGINE BODY IN GOOD CONDICTION CRANKS UP AND RUNS BUT CB JOINTS ARE BAD
CALL JR 843-609-6362
SORRY NO CAMERA
i have nothing to say. LOL
if you want the ad, ****1994 EAGLE TALON***** OBO
oh right, i must of over looked...and forgot about the special 4.3 crank...stupid me. LOL
Here's the engine.
And the typos keep piling up. He meant 4.3L Vortec Engine.
A 262 CI V-6.
And the info from wikipedia: GM Vortec engine - Wikipedia, the free encyclopedia
The Vortec 4300 is a 90° V6 truck engine, replacing the Chevrolet 250 in light trucks and 200 cu in (3.3 L) and 229 cu in (3.8 L) 90-degree V6s in passenger cars. The 4300 is based on the 350 cu in (5.7 L) Chevrolet small-block V8, and first appeared in 1985 with the throttle-body injected LB4 in passenger cars; light trucks and vans used Quadrajet carburetors for 1985. In 1991, the limited-edition GMC Syclone featured a 280 hp (210 kW) and 350 lb·ft (475 N·m) turbocharged and intercooled LB4 with the first use of multi-point fuel injection on a Vortec V6. The central-port injected L35 (Vin 'W') debuted in 1992; the cylinder block was slightly changed, a balance shaft was added to remove minor vibrations, and better breathing yielded 200 horsepower (150 kW). Another CPI engine, the LF6, joined in 1996 with the introduction of Vortec cylinder heads, while the LB4 was retired after 1998. In 2002, GM introduced a new multi-point injected LU3 engine, and a LG3 variant appeared soon after. This engine's origins date back to 1955, when the original Chevy small-block V-8 was introduced.
All Vortec 4300s use a cast iron block and heads and 4 in (101.60 mm) bore and 3.48 in (88.39 mm) stroke, both of which are the same as a 350, which gives them a displacement of 262.39 cubic inches (4,299.8 cc). Connecting rods still measure 5.7 in (144.78 mm) although the rod journal diameter is 2.25 in (57.15 mm). 1992 and later cylinder blocks used a different timing cover since these engines used a balance shaft (some 1992 production cylinder blocks for the LB4 with TBI induction used the 'traditional' front timing chain cover from the small block Chevrolet). They are OHV engines with two valves per cylinder and are produced in Tonawanda, New York and Romulus, Michigan. Power output of the new LU3/LG3 engines is 180 hp (130 kW) to 200 hp (150 kW) and 245 lb·ft (332 N·m) to 260 lb·ft (353 N·m).
4300 applications:
* 1985-2005 Chevrolet Astro/GMC Safari
* 1991-1993 GMC Syclone/GMC Typhoon
* 1988-1995 Chevrolet Blazer/GMC Jimmy
* 2001-2002 Chevrolet Express/GMC Savana
* 1988-2003 Chevrolet S-10/GMC S-15
* 1994-2001 Oldsmobile Bravada
* 1985-2001 Chevrolet C/K
And here's some specs I pulled up.
Specifications
Displacement: 262 C.I.D. (4294 CC) / 4.3L
Cylinders: 90 Degree V6 Cylinder
Comp. Ratio: 9.4:1
Valve Config.: Overhead Valves (2 valves per cylinder)
Valve Lifters: Hydralic Roller
Bore x Stroke: 4.00" x 3.48" (101.60 x 88.39 mm)
Horsepower: 223 H.P. @ 4800 RPM (Carburetor)
Torque: 267 lb-ft @ 2800 RPM
....i think im going to make a run down there today just to look, if it is in fact this motor...and it works...ill buy it LOL
Spoil sport? I'd like to see a picture of that engine in the car. Especially if the guy can't even spell the engine model.
We where having a good time teasing the add for its NONSENSE and here you come and make perfect sense out of it.
LOL no, its a good 2 hours away...
somebody call the guy and see whats up haha
Those engines are bullet-proof. My dads had many Blazers and he even owned a Typhoon for about a year. Man that thing had torque.
It would be interesting to see that engine tucked into a DSM.
That motor and a 700R4 tranny. Might be able to stuff it in there.
