hotrodssnova
- 694
- 46
- Feb 14, 2009
Houston,
Texas
I use tuner pro, and have used the palm, laptop and mmcd droid to log with. The palm was ok back in the day when I was just starting off, and was stock. That thing died, so I needed to another way to monitor things. Thats when I bought the frozen apps device and software when the group buy went down. It was ok for some things, but since I run speed density, somethings did not register properly. The bin I run just was not fully compatible with the android app. If you know anything about tunerpro, you can use your laptop to log and record and tune with, so I was back to using the laptop. Not as convenient, but fail proof, and does the trick....when you have it with you.
That leads me into what I, and basshead, and others have been working on. Props have to go to Sebastien Giroux for developing the android app aldldroid. It is a bluetooth android app that works with a tunerpro adx. It can be found with a simple search on google play. Sebastien has put a ton of work into this app and helped me out a bunch.
The 1g ecu runs at a baud of 1953. That is a non standard rate, and requires additional hardware to be able to be read. I am NOT going to get into that here, or now, just wanted the 1g guys and gals that there are other ways to log your setup. I don't have link, or will I ever have link. I do not know if it will work with link.
With that all said, here is a video that I took:
[ame=http://youtu.be/yRcqss1rVWM]Aldldroid on dsm - YouTube[/ame]
Here's a log. Granted, I still need to set the adx conversions to match what is really going on, but you get the idea. This even logs your speed, lat, long, g force, ect. You really got to check this out.
https://drive.google.com/file/d/0B6T0dzpHGwwoamRZTHlwdFQzNlE/edit?usp=sharing
If there's enough interest, I can do a how to build. All the parts and software are readily available.
