Andrew_99_GST
- 119
- 12
- Oct 18, 2014
Omaha,
Nebraska
I just finished rebuilding my motor (bearing went out). Got everything hooked back up and I went to do the compression test and I realized it was in reverse. When I went to put it in neutral, I noticed there was a lot of resistance. So I ran it through the gears. Results-
1st and 2nd- Minimal resistance (a little bit more than normal)
3rd and 4th- Quite a bit of resistance
5th and reverse- Can't get into them at all
I took off the shift cable linkage and I still can't get it to go into 5th and reverse. Everything was fine before I spun the rod bearing.
The only thing I can think of, is when I was filling up the transmission I thought the fill hole was the hole right under all the shift linkage. I used more transmission fluid than I thought I should've, so I checked again and figured out I used the wrong hole. When I opened up the fill hole, a bunch drained out. I let it drain to the correct level.
This is my DD so I want to get it back on the road as soon as possible. So any help is appreciated!
