local dsm mechanic
It's best to post this in the local forum. Bud.
I goto DMS Performance in Dillsburg.
Ah misread, I thought you were asking about a garage/shop to take it too LOL.
What's up with the vehicle?
its hard to explain ever since i took it to my garage up here and they changed all the belts it seems like when i get up to 5000 rpm i cant go any farther because it vibrates so much and my check engine lite is on saying turbo actuator malfunction
would this have anything to do with the boost control solenoid?
internal Wastegate.
i did some research and found that what the codes for.
now that part cannot set any type of code since its mechanical.
so, what/why is the code set.
How much boost is the car currently running?
and what is the current setup on the car?
and is the boost control solenoid still hooked to vacuum line?
Well have you checked if your boost solenoid is routed correctly?? Or hooked up at all??
If your unsure where it is, its right under your air intake hose bolted close to your coolant overflow tank. Check if all vacuum hoses are attached.
yes it includes the timing belt, and its boosting at 14.5 psi the car ran fine when i got it and then like 3 months later i was driving one day and got on it for a friend and the car almost like cuts out soon as it starts to boost so i cant even give it full throttle with out it cutting out.i mean if i had a garage i would check into it more but its just way to cold for me to do it outside
Sorry didn't realize your throwing a code, I was thinking maybe the oil pump was off, but i don't believe that would throw a code. or at least it didn't in my first gen when a professional mechanic ####ed up my timing.... the reason I learned how to time a dsm.
I'm guessing whoever did the belts, didn't get the balance shaft belt right. Either its not timed right or the tension isn't right. Having the wrong tension will make it vibrate. I would help, but I'm not working on cars anymore.
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
  • For sale AEM Series 2 Total Control Plug And Play Stand Alone ECU For Sale
    I am selling my AEM Series 2 plug and play, fully programable, stand alone ECU. I had bought...
    • LSM
  • For sale 2g 2g passenger side PW switch
    Passengers side PW switch. Good condition. Message 702-741-6987
  • For sale 2GB Factory Owners Manual For Sale
    I am selling the factory owners manual warranty info booklet, and maintenance booklet, all in...
    • LSM
