General Little help with Jackal log please
-=TWITCH=-
826
Sep 4, 2002
Columbia, Missouri
What you need to do is get a log of as many rpm, boost, and load points as you can. Then what you need to do is convert that log into a pivot table with Excel. There used to be some great tutorials on how to do this or call me and I can walk you through it.
Pretty much what a pivot table will do for you is show you as a visual what your actual AFRs are in your load map based on the logged values. So that you know exactly where you need more fuel and where you need less fuel.
Thanks Kletke,
I am almost done with my valve cover, and will be able to get some nice long data logs with as much data ranges as possible. I will give you a call when I have the log ready. Also I will look around and see if I can find a pivot table.
Thanks dude
are you sure your wb is logging right? that looks WAY off. all that fuel and no knock? i posted a short log clip. your wb must be set wrong in the options. i run jackal also and cant get rid of that knock.
Hey Kletke,
Been wanting to set this up on my pc what do you think?
VE Tuning sheet
it works great! just change your map sensor in settings first, then transfer your data, and hit go! remember to change your map setting before you upload your tune.
