Link and Wideband
Depends on what your goals are. Short answer yes, I'm sure you plan on pushing the 16g more than stock boost levels. With ECMLink and a Wideband you'll then be able to move to larger injectors and therefore run more boost.
Well i have a 6 bolt swap, and i throw those random misfire codes... Also, i would really like to push my 16, in the future but i think to be on the safe side to be able to control everything in my motor.
Any benefits other than being safe to turn up boost.
It's definitely worth it. Any car will benefit from being able to be properly logged and tuned. Once you purchase them, you'll be ready for any other upgrades you'll want to throw at the car. There would be no point to buying bigger injectors before you can use them so if you plan to some day push the 16g, it only makes sense to buy link first.
