Likelyhood of Boost Creep?
BlackbirdOfPrey
435
Dec 4, 2003
Shiloh,
I am putting together my setup for a 50 trim and I was thinking of the following mods (this is from exhaust manifold out, doesn't include fuel etc...)
Evo 3 Manifiold
Pte 50 trim/ AGP RS49
3" o2 housing with external dump
3" Dp (replaces cat as well)
3" Cat back
My question is what is the likelyhood of boost creep if I went with an INTERNAL wastegate on the 50 trim? Or should I go straight to an EXTERNAL gate? (the difference is a lot of money and a different exhaust manifold) And also if I put all that stuff on my stock 14b would I still be seeing creep? (and not putting it on until I get my 50 trim) Or would I be ok? The reason I ask is that while internal gates and 3" pipes increase likelyhood of boost creep, would the o2 dump offset this enough to be safe?
It looks like you'll be spending a lot of money on all those parts. It might be in your best interest and consider buying our complete T3T4 Kit. It will come with all the parts you are already buying, and an external wastegate so you won't ever have to worry about creep. Give us a call or send an email to [email protected]
The only problem with that is that I can make immediate use of most of those items (manifold, o2, downpipe, cat back), and can go piece by piece as opposed to dropping 1600+ in one go, and having to install them all at once.
    • george bromwell
    • pma1123
    • Sdcryan1
