leaking antifreeze on 2g gst
exzercist
267
Feb 11, 2004
Adams, Massachusetts
my 98 gst is leaking antifreeze. i checked my radiator and return houses fgoin to the radiator but no leaks. i can see it leakin maybe under the intake manifold somewhere or around there. its leaking onto the tranny where it meets the engine. it leaks off the middle brace that supports the tranny and it leaks all over my dp! anyone know what the prob is?
thanks.
well its not the cap, and its when i run the car and whne i turn it off it leaks both the times. ill check the throttle body. it would be easy to trace but theres coolant streams running everywhere.
well i fixed the two hoses goin to the thermosta housing, this stop some leakin. so its still coming form underneath the intake manifold. so i went to a local shop and they said it might be a blown head gasket! but i dont over heat and the car drives fine. well tomorrow im gonna take the manifold off and see if i can see anything. and more suggestions????? i need help bad.
