launching issues!
what 12.9 in the 1/8th? what mods do you have cause the ones listed in your profile I know wont get you 12.9 in 1/4.
Andrew
I drive a 95 gst its have 240HP, 240 TQ, which is not not too bad its coming along. But i feel that the only way to get traciton is to know how much throttle to put down. Just try to perfect first gear throttle, before you notice when you start to spin. Like see where your limit is, for me there is a certain amount of throttle i can accelerate with in first gear, then at like 5,000rpm i am able to punch it then rip into second and do the same....third gear is just...amazing. Whenever your bored man just go out at night and feel your car out. FWD isnt THAT bad, we can deal with it. w/b
If I do more than half throttle in 2nd Ill spin third in the right conditions and fullk throttle Ill spin you guys are lucky...with the mods you have hold the rpms at about 3k and slip out the clutch slowly ease on the throttle steady but not to fast. At 6k rpms shift to second and slowly step into it and after some gas is applied stomp on it and there ya go basics to launching a fwd...work with that and see hopw it works. Good luck
Andrew
