larger than stock fuel injectors
98gst_dsmr
Aug 1, 2008
ontario, California
what is a good size to use on a stock turbo if i plan to upgrade to a 16g later on?
what will the injectors do for me on the stock turbo?
really dont know much about fuek systems so i would appreciate the help thanks :)
550s will work, 650s would be better.
The injectors by themselves will be worse for your car unless you have a tuning device to account for the larger injectors. If you have that, then you could bump up the boost a little bit. But on a 2G (with the OEM BOV and the T25) it will not be much before you reach the limit of the T-to-small turbo and the leaky BOV.
