stanlis
- 63
- 0
- Dec 26, 2004
east dublin,
Georgia
I have recently purchased a 1998 Eclipse GSX about 2 weeks ago. When i got the car i immediatly changed the spark plugs and wires and the fuel filter. Then a couple days after that i ordered an Extreme Psi intake w/ a K&N. Now here is my problem..When i first got the car it started fine on a cold start and sometimes hot. But most of the time when it was hot instead of my car starting and reving up to 1500rpms, then dropping down to 750, my car would start, an idle at 400rpms then go up to 750. Now that i've had the car for a couple of weeks, it does it when it's cold and hot almost everytime. Okay now for my second problem(maybe something to do w/ problem one or thinking it could be a whole different problem)...I can "get on" my car sometimes and my turbo sounds really loud but my car doesn't hardly move(almost like my turbo isn't working) then at other times i can "get on it" and my car pulls really strong. Other symptoms that i think go along w/ the above, is my oil cap and dipstick smell really strong in gas, and with my car at a dead stop if i rev it to 4 or 5k and let it idle back down there will be a small cloud of smoke that comes out( it looks like a blueish tint but not exactly sure)..I'm kinda thinking that the smoking thing is either my turbo or my car running rich???...Things i've checked so far for is...checked for boost leaks and only had a small one coming for the bov..i've ran injector cleaner through my car several times..checked my coil packed and got 16.4k ohms between 1&4 and 2&3, then at the 3 pin connector i got different numbers each way i tested it and all of them where above one?... Any help would be greatly appreciated..Thanks in advance!
, so i didnt know if maybe the coil pack was having to strain extra hard to make a spark or something and wore it down.. What's ya'll opinion on my numbers and that situation?
.. I was just wondering with my coil pack being out of spec, is there a chance that it's not delievering enough spark at mid or high rpms to make my car pull timing like it's doing? I'm pretty sure i'm gettin enough fuel, cause all i can smell is gas everywhere.... Another problem i'm having now is, i installed a greddy type rs and now my boost is going crazy.. It will shoot all the way up to 20 psi and sometime it will be 15, for some reason it's different in every gear??? Also i will be taking out the knock sensor today and giving it a look..
