Anthony Boni
5+ Year Contributor
- 212
- 23
- May 13, 2018
Wrightstown,
New Jersey
Hello all!
I'm trying to install my Koni suspension and Ground Control coilovers on my 92 eagle talon. The front Koni suspension is for a 1G, while the rear is for a 2G because the rear 1G Koni rear struts are discontinued.
The first picture is the instructions given to me from Ground Control. Provided is a spring isolator, and a red cup washer. At the very top of the page, above the spring isolator, there is supposed to be a steel ring. After calling Ground Control wondering where the ring was in the kit, they notified me it is a stock component that is transferred over to the Koni unit. Can anyone confirm this? I've no idea what steel ring they are talking about.
In the first image, you'll notice I installed the perch onto the strut and installed my bump stop. The instructions state to cut the stock bump stop in half and use the top portion, so that's what I did. It fits very loosely though, normal?
The second Image is the same as the first, now with the spring installed.
The third image is the same as the second, now with the spring isolator installed.
The fourth image is the same as the third, now with the supplied red cup installed. I had to drill out the center of the red cup to make it fit onto the Koni strut. The hole was maybe a 1/4". To make it fit, it needed to be around 7/16". My assumption is because I ordered GC coilovers for 1G front AND rear koni struts. When the reality is I have 1G front Konis and 2G rear Konis. Perhaps that red cup only fits 1G rear Konis, and I had to modify it to make it fit the 2G rear struts.
The fifth image is the rear upper mount. It is not the one I will be using, just an example of what is actually on my car right now.
The sixth image is just resting the top hat on the red cup washer seen in the fourth image. There is nothing in between the red cup washer and the upper mount, just as the instructions imply.
The seventh image is me installing it the way i think it is supposed to go? The instructions only say "stock upper mount", so I am unsure what bushings go here, or if I am missing something? It also says to discard the stock dust boot, but in the image shows a dust boot being employed. I AM CONFUSION!
And finally, the eighth image what it looks like with the rear strut/coilover completely installed.
I could really use someone to point me in the right direction. What am I missing? What steel ring is it talking about? Why did I have to drill the red cup washer to fit?
Thanks,
Anthony.
Thanks,
Anthony.
. I’ll take pictures and measurements of the red cup when I get back home. I’ll be back on the 14th. Took leave to Virginia to visit family. Thanks for the help!! I’ll update this as soon as I get pics!
