Knocking or tapping sound when car is off
Deuce of Spades
79
Apr 14, 2008
El Paso, Texas
About 5 to 10 min after i shut my 96 GSX off it makes a slow, deliberate tapping sound for about 30 sec. Then it gets very rapid, similar like an electric motor or small air compressor, for a few seconds and stops. A minute later it goes thru this cycle again and this goes on for about 20 mins or longer. To make matters more weird sometimes when i go to start the car it will barely idle until I give it gas. And the last time this happened it took about 10 min to start the car. :confused:
All of this happens once a week, sometimes less, and i drive it everyday.
Its hard to pinpoint but it seems like is coming from the rear of the engine near the firewall. Not positive though....:confused:
My engine does the same thing. I've narrowed it down to the valve springs. I can't explain why they are making the noise, but they definitely are. I can push on the t-belt between the two cam gears and increase the rate in which it ticks for a couple seconds before it stops. I have yet to find anything wrong with any part of the engine, but it's been doing this for 1-2 years with no negative affects.
Try pushing down on the t-belt and see if that affects it on yours.
Is it possible for a lifter to still actuate with the car off? I know sounds like a totally dumb questions just wondered if maybe they are still under hydraulic pressure right when you first turn the car off. I understand that the oil galleys pressurize the lifter and I would assume that maybe you are hearing the pressure being relieved from the lifter.
ISC seems more logical.
Definitely sounds like the ISC
Thanks, I will check it today at work.
I will try it as soon as it makes the noise again. I havent even considered that fact that theinfrequent rough starts might have nothing to do with the sound at all.:hmm:
I would poop the hood and see if you can pin point where the noise is coming from if ya can. i know valve springs like to tick or pop when you shut the car down.
Interesting, my car does the same thing but I gave up trying to figure out what was making hte noise, ill have to try this.
Yeah, mine started doing it after I rebuilt the head with my Kiggly springs and Kelford 272s. It never did it on a stock head. Although I'm not worried about it at all, I'd be interested to learn why it does it.
You know how your exhaust pipes tick and pop after a drive, because they start cooling down. Could the valve springs be doing the same thing?
That sounds way more reasonable that what you are hearing is the spring as it is cooling.
But the sound is not random its a very set pace then rapid and back and fourth. It sounds like some kind of electric motor.
Its sounds nothing like the ticking of a car cooling down
If it does it when I get home I will post a video
By the way you phrased this it makes it seem like it doesn't happen everytime. Is it a consistent event or does it only make the noise occasionally?
