silvreclips
- 1,279
- 348
- Jul 19, 2005
Greenville,
South Carolina
Ok guys, Ive been looking and replacing parts in the front end trying to figure out this suspension knock I keep hearing. It seems to have gotten a little better but is still there.
Background: The knock is deffinately coming from the front passenger side of the car. It can sometimes be heard on hard 1st to 2nd shifts. Mainly noticeable on hard launches the last time I was at an autox. Also the last track day I did any time I hit a gator on the right side going into a corner there was a loud pop, to the point my instructor was a little bit worried about the car. I have also heard the noise under hard braking conditions.
Here is what has been replaced in the last few months trying to track this down. New tie rods inner and outer. Alignment was also done. Poly sway bar bushings, sway bar end links. New lower compression arm with ball joint, new lateral arm with ball joint, new upper ball joint.
The only thing I have not replaced is the anchor bolts for the upper control arm, they seemed to be in ok shape and Im not sure where to buy just those parts.
Or I was thinking it could be the subframe bushings. I hate replacing parts for the hell of it so has anyone had this issue before.
Any help is great
Any help is great
