Knock... Any ideas would help
crazyquik22023
641
6
Sep 14, 2008
Akron, Ohio
I am getting alot of knock at 15+ psi... Im not sure why i don't think im running too lean but i could be wrong.. my wideband is at about 10.6:1 on WOT. and i think i have my timing set up pretty good. Here is a log let me know why you guys think im getting so much knock and it will sometimes go higher up to 12 degrees of knock.. also since this log i have raised my 4000-8500k rpm fuel sliders to about -4# or so...
Yes your timing is way too high. I see that you have raised the timing sliders 6 degree higher at high revolution. you should have them zeroed out and use the
ecu direct access maxocttiming table to adjust it properly. Look at the ecm tuning
site and watch for the demos. You will see how to track datalog and to set the timing map in relationship with your knock count.
